Wilson
Has any one installed a power invertor on there tow vehicle to plug in the block heater while trailering . If so how big does the invertor have to be . There must be some electrical guys out there that know about this stuff .
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
Wow. It's a great idea, but that block heater draws about 600 watts. That's going to require about a 50-60 amp circuit and the inverter itself is going to be about $250-$300. You would have to direct wire it to the battery, but you might find that your alternator and battery don't have the juice to keep up with that kind of continuous draw.Wilson said:Has any one installed a power invertor on there tow vehicle to plug in the block heater while trailering . If so how big does the invertor have to be . There must be some electrical guys out there that know about this stuff .
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
BigMac said:Wow. It's a great idea, but that block heater draws about 600 watts. That's going to require about a 50-60 amp circuit and the inverter itself is going to be about $250-$300. You would have to direct wire it to the battery, but you might find that your alternator and battery don't have the juice to keep up with that kind of continuous draw.Wilson said:Has any one installed a power invertor on there tow vehicle to plug in the block heater while trailering . If so how big does the invertor have to be . There must be some electrical guys out there that know about this stuff .
DUDE, try 5-6 AMPS!!!
BigMac
- Jun 27, 2004
Oops, right...divide by 120 not 12......QCRider said:DUDE, try 5-6 AMPS!!!
Flipper
- Oct 31, 2003
- Ottawa, ON
- 2018 SideWinder LTX LE 50th
- Ottawa
This one got me thinking, amazing how fast you forget. It has been a little while since I worked with any inverter circuits....
5-6 amps would be correct for the secondary side of the transformer which would be operating at about 120 volts (600 Watts/120 Volts). On the primary side, assuming a center tap transformer (24 volts across primary winding) it would be around 25 amps (600/24). Actual values would be slightly higher than this due to losses I believe.
I would want to look into the ratings on your vehicle's electrical system before trying this. I know my Freestar van has 12 volt outlets each fused at 25-30 amps so I assume it would handle it.
