Practicing with the FX Nytro; Like to Introduce Myself
08 FX Nytro lover said:
xc_phazer137 said:
How so Sir? because I added waight to the front end. I used the same geometry as you folks. Stock shocks. I really dont know what the issue is. Just like the Phazer deal some like there sled some dont. I happen to like both. I gess some like to read what others are doing and some dont.
Apples and Oranges Haha. Understand something if you plan on wrecklessly going out pounding over stumps rocks road aprotch's ect. your going to want all the re'forcing nessasary. Not saying A arms are week, saying I hate to hit a stump and bend an A arm because I did not re'force my A arm's. "its just protocol"
I see your a 08 Nytro Lover?
Yeah apples to oranges. A stock subframe compared one that has been modified is apples to oranges. I havnt "wrecklessly" hit anything with mine and the right ski is 2" further back then the left. Not a scuff on the ski's, carbides or spindles and I dont jump my snowmobiles period.
btw, I was what my name says but that has since changed. I got a little ahead of myself on here after picking this one up for such a great price with 2' of snow on the ground and lots of winter left to ride, but now Im seeing why I got "such a great deal"
did you buy unchained sled....?
I have not got with Rick yet. The machine I used had stock factory valved fox floats none evol and stock rear shocks RTX I changed fluid in them after the BIR 100 mile hybrid race half sx/xc. We did bump the nytrogin psi up to 250 from 200 the book called for. This did help. However I would recomend going with "stiffer" valving not psi. We did not have any valves in stock. So it was my desision to bump up the PSI.
Yes I use the float evols and podium rear on my race quad and I belive we can get the same results I am looking for out of the nytro, Next year tho.
unchained sled? Not sure what that is?
FYI I did not have a re'enforced sub frame. I had re'forced A'arm's and spindles.
Sir Why your A'arm is bent back I would have no clue.
