uofm
i have brand new ski doo precision skis and i would like to put them on a rage. the skis have the brackets already on them. they were taken off from a new machine. i checked into the ski doo kit but it cost $140 can someone tell me how they were putting them on the rx1 the past few years. what will i need to do this. any info would help. thanks
Boston RX1
I have them on mine as well and I do believe you will need the kit. I am sure someone here will confirm that as well.
Gilbey
I have the mounting kit on mine with the boots. I'm sure that you could modify the existing ones if you tried. You may have to throw some shims in so that they align properly.
With the mounting kit it's a very easy process, maybe a good part of an hour.
Brad
Brad
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
There is a way to modify them. Use the search fuction.
LazyBastard
If I recall, didn't that modification involve chopping up the Yamaha ski saddle? That being the case, wouldn't work on an RS since their saddles are plastic molded in.
only 05 has the saddless skis?
VMX
- Nov 9, 2003
- Ma.
- 2006 GT ,2007 RTX, 2011se
i have these on my 04 turn brass bushings around and find some .080 aluminum plate cut to same size as rubber ski bumper then use automotive goop and glue plate to rubber get 4 .040 washers from dealer 2 per ski and install
uofm
anybody have pictures?
Snomad
- Apr 14, 2003
- Lockport, Mb.
- www.whiskersandwalleye.com
If memory serves, someone managed to modify the '03 RX-1 saddles to accommodate the precision ski. I used the skis with the mounting kit as I wanted to be able to remove the precision skis if I were to sell or trade the RX. I think you had to reverse one bushing on each ski saddle, use thin washers for spacers and use the longer ski bolts that came with the kit. Also, the rubber bumpers that come with the kit seem impossible to install because the spindle to saddle angle is different from the RX-1 to the Ski-doo. This actually works to advantage because when you manage to get them on (with help) you will have basically a ski with shims under the rear of the bumper. This will help with darting and steering resistance and helps keep the skis up in powder. When you jack the front of the machine up off the floor you will see what I mean as the ski tips will be up instead of level.
