primary clutch question
rough rider
minnesota
Can anyone tell me if the 4 stroke primary clutches will bolt up to other 4 stroke engines, Foe example a warrior to a vector or apex clutch to vector, Im looking at a clutch for my vector and found a used one from a 2004 warrior and just wondering if it will fit crank? Thanks for any info
Clutch housings are all the same . You will have to change the weights and primary spring and possibly the rollers.
Make sure you check the surface if the clutch you are buying. The 4 strokes can put grooves in them and that may be the problem you are having with yours. Also check the cost of new sheaves from a dealer, it may be cheaper than replacing the whole clutch.
