djburr
I recently bought a well used 2009 RS Viking. Clutch was loud compared to my 2006 VK Pro, so I had a rebuild kit put into it, its still noisy. Please see attached clip, can anyone identify what's causing the rattle while its running, still functions fine. Thanks!
the idle sounds low from the sound clip.
djburr
Idle is within spec.
djburr
Are you recommending the idle should be set higher to make the rattle stop? If so, what RPM do you recommend?
try it at 1500 as the same motor is in the venture/vectors from that era. spec on those is 1450-1550 rpm idle speed.
the 3 holers are notoriously harder on clutch parts and a bit of a rattle on them is considered normal.
Did you put new spider buttons in? Did you shim them with the shims that Yamaha offers.
djburr
I had a guy put the rebuild kit from royal in it (SM-03249). From what I am hearing if I spin the track and the rattle goes away, its fine. Thoughts?
yamrx1
2017 rs viking idle recommend right off machineI recently bought a well used 2009 RS Viking. Clutch was loud compared to my 2006 VK Pro, so I had a rebuild kit put into it, its still noisy. Please see attached clip, can anyone identify what's causing the rattle while its running, still functions fine. Thanks!
yamrx1
2017 rs vikingI recently bought a well used 2009 RS Viking. Clutch was loud compared to my 2006 VK Pro, so I had a rebuild kit put into it, its still noisy. Please see attached clip, can anyone identify what's causing the rattle while its running, still functions fine. Thanks!
yamrx1
- 13K
