hi
since i install supercharge
engine make lot of over rev (12 400rpm +)
-I try bigger rivet (2x 4.5g) from yamaha in the stock weight 8dn-17605-30 40g (total 49g) and same thing
no good result
-I install Schmidt Bros Motorsports stage2 kit (300$) with helix, front spring, and rivet (total 53g)
no good result
-after I add 1 tooth in chain case gear
no good result
-so I change secondary (yellow) spring position from b1 = 60 degre like said by Schmidt Bros Motorsports
and switch to c1 = 40 degre
no good result
so now the last thing i can do is to buy expensive weight from yamaha ?
if yes which one?
yamaha have listed for phazer in is optional part for primairy clutch
-68g ,3 holes 141$kit (all phazer) 8fp
-65g ,3 holes 203$ kit (all phazer) 8fs
-47g, 2 holes 139$ kit (all phazer) 8gc
-40g, 2 holes 152$ kit (MTX only) 8dn (mine now)
my first choice it's to go with 68gram 8fp-17605-00 ?
give me your advice
thank you
no good result
no good result
no good result
no good result
if yes which one?
give me your advice
thank you
Skionlrghills88
- Dec 11, 2012
sounds like we have the exact same problem!
Ulmer got mine right on the $.
I find 6 year old thread
there is tell about 63g
http://www.dootalk.com/forums/topic/137 ... phazer-fx/
Call Ulmer he can take care of you.He will know just what weights to run.Deals with this all the time.
