Rove44
I was out riding today on my 03 RX1 and I shut it off at a gas station and it wouldn't start back up. I was given a jump start and it fired right up when I took off and started to ride the gauges quit on the dash pod. I shut it off and it wouldn't start again. I got another jump start it fired right and worked.AS I was riding the gauges quit again and it started to lose power.slowed down and I came to complete stop and it wouldn't even move. The sled has 5300 miles on it. If you have any advice on this matter it would helpful.
Thanks!
Thanks!
Highmiler
Rove44 said:I was out riding today on my 03 RX1 and I shut it off at a gas station and it wouldn't start back up. I was given a jump start and it fired right up when I took off and started to ride the gauges quit on the dash pod. I shut it off and it wouldn't start again. I got another jump start it fired right and worked.AS I was riding the gauges quit again and it started to lose power.slowed down and I came to complete stop and it wouldn't even move. The sled has 5300 miles on it. If you have any advice on this matter it would helpful.
Thanks!
Sounds like you either have a charging problem or your battery is shot!!. If battery is original, that would make it 6 years old, so just put a new one and try it.
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
I had the same thing happen to my sled look for chaffed wires under the tool box. My problem was the regulator in the very nose of the sled was unplugged.
04rxw10 said:I had the same thing happen to my sled look for chaffed wires under the tool box. My problem was the regulator in the very nose of the sled was unplugged.
my first thought too....
So many problems caused from that!!!!!!!
Rove44
Put new battery in fired right up gauges worked 2 minutes later gauges quit working and lost power. turned it off and it would'nt start again IM STUMPED
04rxw10
- Jan 28, 2008
if you looked over all the wires and a new battery I would think stator. But look everything over again to make sure before spending that money
Rove44
I need to thank 04rxw10 the regulator was partially un plugged i don't know how, but i'm good to go thanks for all the input this site is the best source for info
04rxw10
- Jan 28, 2008
No need to thank me just here to help and get input from the quality members in here.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
Had to be regualtor battery would run the sled for more than 2 minutes brand new
