Problems with anti ratcheting drivers
Cilius66
Norway
I bought a set of Kimpex anti ratcheting 9 tooth to my 2003 RX1.
But when I was mounting my suspension the teeth from the drivers touch the first fastening point on the suspension.
Is the 9 tooth to big?? Or is it me that have done something wrong??
if you have a pro action or m10, you will need to cut the tips of the drivers off, or turn it down on a lathe. i found out like you after the track was in and just used a new sheet rock blade and cut them all back, pain in the a$$$.
it was only like 1/4 in as i remember.
i had the same problem with my m10, except i read on here somewhere they where not going to clear so i took the front arm out of my suspension and test fit the clearance without the track installed , i used a grinding disk to shorten them, then assembled and spun and marked the ones that where still alittle long, took few times in and out to get it rite
I have removed the shaft with the drivers, a neighbour is cutting them down in his machineshop.
When cutting one and one, I am afraid them gonne get unbalance.
