07ApexRTX
- Jan 25, 2007
I just installed my proline clutch kit and the sled has a vibration in it when on the throttle. Once off the throttle smooth as usual. Any ideas?
ROCKRTX
If i was you,recheck everything on the primary clutch. Maybe something loose and you dont want that at those fast rpm.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Did you get the cover back on properly? The x on cover must line up with the x on spider.
07ApexRTX
- Jan 25, 2007
KnappAttack said:Did you get the cover back on properly? The x on cover must line up with the x on spider.
We have a winner! Thanks.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Try putting in another belt. You may have a flat spot on it causing a vibration.
07ApexRTX
- Jan 25, 2007
BADSLED said:Try putting in another belt. You may have a flat spot on it causing a vibration.
I though the same thing but it did not help,thanks.
