bad vibration
robert327
Renfrew Ontario
hi guys i am having trouble with a very bad vibration . my engine idles smooth and when i go to take off it vibates so bad it shakes my hole sled till i i get past quarter throttle then it smoothens out cant see any cracks in exhaust and it stalls when i plug exhaust tips . i rebuilt my clutch but stiil can i run engine without clutch on to see if its the clutch or any other ideas thanks in advance
I would check the belt carefully as a first step. You could try putting on your spare belt as a way to test it.
that does make sense ive checked all bearnings because i think it was driven with emergencie break on anyway to make sure thanks
had some problems with front drive shaft cracking, almost have to have out to check, near drive sprockets, do asearch i'm sure there is pics somewhere
is the vibration there if you run it with the belt off?
