pulley #'s equal boost #'s
Ratpack
Frewsburg NY
2003 RX1
Last year I had 24 pulleys on the top and bottom and had 7 lbs of boost. I told MPI that I wanted 10 lbs and they sent me a 26 tooth for the bottom. Now it has 15 lbs and is running lean. Any ideas?
Makes no sense.
22/26 is 5.5 ish psi.
26/22 is 10.2 ish psi.
No way 26/24 should be 15 psi.
Bad guage? Obstruction somewhere after the boost pick up.
no it doesn't. The chart says that combo should be 9.2 lbs. Wouldn't an obstuction in the boost line make it show less boost. I am going to change back to 7 lbs and see what happens.
Nope. Its an RX1. I think that it does not have good vaccum so it's not raising the needles like it should. Now I just need to find out where the vaccum comes from and what is wrong with that.
