sneakattak88
Have a 2003 rx1' with k&n filters, did jets,pilots, ect, sled start runs great, i pull it out hammer it and it bogs, the all of sudden it pulls hard, let off throttle and big bog, I check just a bout everything I can think of,, at wot it pulls hard,, just that bad bad bog,, the tors has been bypass. Carbs pulled off , plugs checked,, just no clue. Need help now
HOMEHARDWARE65
I am no mechanic at all but seing you have a turbo it could be turbo lag???? I have no clue
sneakattak88
Sorry no turbo on this one,,turbo is on Attak
the kitchen
A very common mistake with the K&N upgrade is changing the wrong jet. The main jet will fit in and looks identical to the jet beside it. The main jet is at the center of the bowl and is two peices. This is the exact performance problem when this mistake is made.
rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
I know this was years ago but what did you end up figuring out to fix the problem?
tedgoesfast
has to be jetting check and double check
