BoostinXtX
- Jan 11, 2014
Hey guys! I just got a push turbo nytro xtx that is setup for low elevation. It's going to be mostly ridden in MN and the UP. The sled is running at about 14 on the air/fuel gauge and is very burpy. It's almost not rideable in powder because it hesitates. Could someone please send me the recommended settings for the Gen3 I would like to compare it to what it's currently set at. I think something got changed. Thanks guys greatly appreciated!
ny01srx
- Feb 20, 2005
- Rochester NY
- 13 nytro
how much boost are you running and what are your settings now? what did you do with clutching........
BoostinXtX
- Jan 11, 2014
Thanks for the reply, it was recommended I make these changes and I think it did it:
green=1-2
yellow=2
red=3-4
green blue=6
yellow blue=6
red blue=4-5
My yellow blue was set at 4 not sure how that got changed. a/f reads perfect now.
I'm running 8psi and not too sure about the clutching.
green=1-2
yellow=2
red=3-4
green blue=6
yellow blue=6
red blue=4-5
petetown
- Jan 6, 2012
- Melville,SK
- 2011 nytro xtx boooooosted!!!
I also have this setup at 10 lbs and low elevation can't seem to locate a good clutch setup?
Sven
Buy Supertip weights and put on weights to 78 gram. Works perfect for me, they are adjustable so you can tune it in the future if you change anything.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Guys - Please add Your location to Your user profile, it's a site requirement.
rxrider
TY Management Team
rxrider
TY Management Team
Sven
rxrider said:Guys - Please add Your location to Your user profile, it's a site requirement.
rxrider
TY Management Team
Done
petetown
- Jan 6, 2012
- Melville,SK
I have supertips I have tungsten in heel and I believe 4 washers middle and tip just not to sure on which springs to buy and what rate of twist on secondary I was kinda wanting to up my engagement a little in the process!Sven said:Buy Supertip weights and put on weights to 78 gram. Works perfect for me, they are adjustable so you can tune it in the future if you change anything.![]()
f7straightliner
14.5 rollers 50 gr base weight super tips with a tungsten on each side in the heel, 4 washers on each side in the middle, and 2 washers on each side at the tip on my mtx. Its a tad light but works good for me in powder.
Sven
petetown said:I have supertips I have tungsten in heel and I believe 4 washers middle and tip just not to sure on which springs to buy and what rate of twist on secondary I was kinda wanting to up my engagement a little in the process!Sven said:Buy Supertip weights and put on weights to 78 gram. Works perfect for me, they are adjustable so you can tune it in the future if you change anything.![]()
Ok i changed to the helix that comes with the turbo but not sure if i changed the spring, dont remember but can check. I Think it works great as is.The engagemant is ok for me.
