SJYAMAHA
Quick question just got my Nytro XTX with Push turbo 200 (low elev.)kit ready for first trip out tomorrow wondering what numbers I should be readinfg on AF guage as well as my boost guage.
Thks
Cant wait to try this out
Thks
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Nothing more than 12.5 AFR on wot.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
11.8-12.0 and your all good.
larrymillwork
- Dec 12, 2012
Just took my push turbo rtx for a spin and all I can say is holy #*$&@! It's unreal! Hitting the limiter on take off little clutching and it's the perfect set up for the all around rider.
Finally getting some snow around these parts
and had a couple more short runs in since the install. Pulls like a train!!!
Set-up looks to be good and runs great, except for running a tad rich down low - 12.5-13 af when on light throttle. Anyone have tips on leaning this thing out a little down low with the Push controller? Already have the green and yellow sat at 1.
Running sea level with 94 octane.
Pstn head
Friend of mine is also running the push turbo, if your 94 octane gas is from Sunoco try using 91 instead because the 94 has more ethanol, ( so I've been told ) what he is using to bring his af readings down is octane boost with lead in it,about 100 ml per 40 ltrs if his readings are high
Also try calling push turbo directly he's been very helpful with his set up
