JERSEYJOE
Runners
Since I already have the Bergstrom triples, I was going to try them again this time without the ski saver. Scott Bergstrom suggested I try this first. I will also increase the front spring preload a few turns, and do the transfer rod to the minimum setting ( 35 mm).I hope this all helps
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Whatevever changes you do .................. do one thing at a time and try it. Thay way you will know and feel what changes affect what. Try it one afternoon. That way you can see same trail same conditions.
Had anyone tried to change the Ripsaw 1,25 track for a one inch lug track? Last year, I went with a predator on my RX-1 and it made a huge difference. This year on my Attack, I didn't. Or it pushes, or both the track and the skis stay planted and I have to fight to have it turned in twisties. If I go with an Attack mext year, maybe I will put a Ski-Doo .9 lug fully clipped and Ski-doo Pilot skis.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I am beginning to believe that alot of our "front end" complaints are caused by our rear suspension set up.
I backed off the transfer rod from 3/4 to min transfer to standard or Middle. :ORC
WOW what a difference in the front end feel, more push, much less 'rail' and only mild increase in wheelie type ski lift.
This is a real balance issue and I think the reason some hate, some love the same product is a different balance of many variables.
I agree with sled freak back off the ski lift and the the push will reduce.
My two cents
Yamadoo
My two cents
Yamadoo
