MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
I currently have the TD multi map with TD dash flash but been thinking of buying the flasher so I have all available TD flashes like SM flashes in case I go somewhere I need to run my stock exhaust. If I buy the flasher do I have to buy the multi maps again for the flasher? Thanks for any help
No. Whoever uploaded your maps before from the updater to the flasher would need to upload them from the same updater to your new flasher.I currently have the TD multi map with TD dash flash but been thinking of buying the flasher so I have all available TD flashes like SM flashes in case I go somewhere I need to run my stock exhaust. If I buy the flasher do I have to buy the multi maps again for the flasher? Thanks for any help
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
Ok I was wondering that cause I had Woodys Yamaha in Topsham ME do everything. Once I get the flasher would I get all available flashes with a update from TD?
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
Probably best to also buy the flasher from Woodys too I would assume.
If you bought all the stuff from Woodys then I would discuss with them, yes.Probably best to also buy the flasher from Woodys too I would assume.
