happy1426
yes boy... Not even broke in yet!!!!!!!!!
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
17362 miles, still plenty!yes boy... Not even broke in yet!!!!!!!!!![]()
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
You will notice it at the end of a ride. Jumping back in forth from RX-1 is instantly noticeable. You work much harder on the RX, so on real cold days I like riding that one.
happy1426
Still not working I started the sled in the garage the other day and it turned to the right on its own... Any ideas what might be wrong or going on here??
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
Any update on your eps trouble. Mine is the same way. Eps light comes on, 5 mins after start up. Can't find the problem
happy1426
No I think mine is the control box..
ualav8
looks like kilometers
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I've encountered this recently too. EPS lights up on the dash full time while riding, which indicates a problem with EPS. I turn off ignition and turn back on and the EPS light is off, but comes back on shortly after.
My understanding is that there is a 40amp fuse under the airbox. I think I'll check out the connections. It seems my issue starting to happen a couple of weeks ago when I was doing a little drift busting. Maybe too much snow entered the engine bay and too much moisture got into the connections.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
My problems with power steering came back, worsened and now no longer works. After entering the EPS diagnostic mode, I retrieve a code 11, which indicates a fault with the torque sensor. The torque sensor isn't serviceable nor can it be purchased through Yamaha... So I need to replace the whole power steering actuator...big bucks! I've purchased a used unit, so hopefully this will fix my issue.
Anyone else encounter the same fault? Has replacing the actuator remedied the problem?
happy1426
Can u explain to me how to do the eps diagnostic code thing thanks so much!!!!!
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
happy1426
Funny I never seen that in my service manual.. But thanks so much I'm a try that when im home !!
FRANK
- Dec 21, 2006
Hi Grimm, Sorry your having issues with your EPS. If you don't mind me asking, how many Kms on your sled? Almost 18k on my SE and no problems at all with EPS. I havn't heard of anyone else with issues. So far my SE has been super reliable and I plan on keeping it for a few more seasons. Good luck and keep us informed.My problems with power steering came back, worsened and now no longer works. After entering the EPS diagnostic mode, I retrieve a code 11, which indicates a fault with the torque sensor. The torque sensor isn't serviceable nor can it be purchased through Yamaha... So I need to replace the whole power steering actuator...big bucks! I've purchased a used unit, so hopefully this will fix my issue.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I've clocked just over 14000km on my sled. I wonder if it may have something to do with the aftermarket skis causing more workload on the EPS system. I've installed a couple of pretty aggressive skis over the seasons and lately with USI Triple Threats, when EPS isn't working, it becomes a bear to turn the skis. I made my own "power steering plates" (as USI calls them), and it makes the skis turn easier, but still engages EPS fault.
There are a couple people out in internet land who have experienced failures in their EPS system and either had to change out the steering actuator or power control unit. I even saw some failures on the Yammy Grizzly ATV forums...ironically, identical part number. But the silly thing is, you can't just buy the torque sensor. You have to buy the whole assembly, which is costly ($1450 Cdn + 13% tax). How nuts is that?
FRANK
- Dec 21, 2006
Always ran OE ski with Snowtrackers (semi) until bent ski & both left A arms recently. Wanted to try the Tuners so replaced with them. Not quite as good as trackers but never had the light go on either way. You could be right about agressive ski& carbides could trick the system into thinking something is wrong and eventually screwing up the torque sensor. Sucks that you can't just buy the sensor but glad you could find a used unit! At least if it's not the sensor you have the whole unit to play with. Season's pretty much over now but off to Sensplex tonight for the show, not that there is anything special to see, just an outing with the boys.
