Question on Track heights...
FormulaPro
Boston, MA
I am trying to find out if I can order a larger track to be installed from the factory (dealers around here aren't much help) on a 2007 Attak GT Spring Check order.
and... if I can't factory order this... does anyone know if a 2" track will fit an '07 Attak?
Thanks in advance,
Keith M.
I'm in the process of getting the PN for an Arctic Cat 1.6" track, trying to find out if it is fully punched, so that internal/external drivers can be used. I'll post the AC PN# when I find out.
Arctic Cat part # 0602-904 136x15x1.6" fits right on.Got it on my Attak.200% better pull in snow then the rip-saw 1.25
Is that AC track fully punched for extovert style drivers?
No driver changes necessary with the AC track?
If not..this is exactly what I am looking for!!
Thanks Zippy... this has further clinched my decision to blow my nephews college fund on a new '07 Attak!!
WHOO HOO!!!
keith M.
Zipclean, thanks for the PN#... did you change out your drivers to the internal/external type? If not does it want to ratchet in the heavy deep stuff. I'm going to change mine out just so that I can run the track looser, these yamaha's just need the track too tight to prevent ratcheting in max traction conditions.(JMO)
Yes the track ratchets once in a while in 3' of heavy snow,I just tightend the track 1/2 turn and will see if that fixes it. No, I just have the stock drivers on,but ya external would let you run the track much looser.We seldom get the kind of deep wet snow we have right now.
