Black 1000
Ok so got my ECP kit and I have a few questions. What are people doing with the small vent line to the bottom of the air box on the left hand side while looking at the sled from front? I have seen posts that say needle position one clip up what does that mean? And any other tips as I didn't get install instructions. I have pmed Freddie as to this and I'm sure he will respond but I'm installing this weekend.
Thanks to all
Thanks to all
ECP Kit
Leave the needles in the stock position and be sure not to lose the small o-ring under each cap when changing the springs! The (vent) that you refer to is a drain and you can either remove the hose or leave it there. Good luck!
grader
the vent line you refer to is just a water drain line in the stk. airbox. ignore it its not needed with kit. needles stay stock from reading previous posts.
I just installed mine too and it rocks ,but I had a bit of a hesitation on the bottom end. I did a search and found the answer was to adjust the fuel screws out to 2- 2.5 turns .
I didnt get that done but cleaned my plug caps and put some dioelectric grease in it and my low end hesitation is gone .
I am not saying you wont have to adjust you screws but do you plug caps first .
Ger
Oh ya , I would look into the evac kit as well
Ger
