Quick hook up for heated visor on 2017 SW
If the Yamaha dealer doesn’t have any check with a Cat dealer they use the same cord. Center terminal is positive
It *should* be the male prong.
I am pretty sure the female is the positive .
any idea how many amps the outlet at the chaincase is , as the stock attachment does not seem to have a inline fuse .
The female side on the sled end would be positive. In the picture of the cord that you posted, the male prong would be the positive side.
does a heated visor really care which wire is positive or negative ?
So I found out no it doesn't matter .
Some people are changing from a 2 amp fuse to a 5 amp .
Does the 5 amp , allow the visor to heat up more ?
I doubt polarity would matter for the visor itself. My concern would be the connections. If the center is positive it would be protected and be less likely to short out. Here is a picture of my factory plug. If the outer ring was positive it could be easier to short out. I would make sure the center stays positive for that reason.
Apparently people are reversing it , so that when the cord pulls out the male end touches the frame and blows the inline fuse, if not reversed .
