DooFighter
Anyone who saw the sleds at the show, can you tell me if the handlebar setup on the rage is same as vector (low) or like the mtn vector (or somewhere in between)? Thank you!
srxmiller
It's the same as the warrior. Which when I sat on it at the show seemed fine,and I didn't think they felt as low as the vector. So I can't say for sure, sorry.
Slush Monster
I was reading the new issue of snow tech they said that the warrior
has a higher windshield than 04 is this due to the higher handlebars
that it has this year and higher seat ? Does anybody know if the
rage also has the higher windshield? Seem like it would since it has
the higher bars like the 05 warrior and thicker seat like the 05 warrior.
I also noticed that the rage has the wide running boards like the warrior
but the vector does not. Rx1 has the wide boards. Why leave the vector
out?!
out?!
srxmiller
I'm sure yamaha left some stuff off the vector to keep the price down.Thats why I chose the rage,all the cool stuff and a lighter motor,with lots of torque.
p0wd3rp1l0t
i do know that the angle of the tunnels is steeper on the rage and warrior, so that might make the handlebars seem different. i personally didnt think the handlebars were tall enough, but im 6'1. but to solve a problem either put a 2" block lift-which you wont have to change any cables, otherwise a 3" block you'll have to change throttle cable and brake hose. i put 2" block with 05 sxviper mtn handlebars for a total of 6" of lift...chopper???
