trucknut
trucknut
sorry about the double post!
trucknut
trucknut
Yama-Crazy
So how does that handle with the M-10?
trucknut
I put 250 hard miles on it last week it definetly has some ski lift but i was really running hard trying to keep up with my buddy on my viper so I was pushing it.the ride is awsome and it was probably set up to stiff for me but i had to start somewere!I don't have any snow here but will hopefully be trailing up north tuesday and will see how my adjustments work.also it looks higher than it really is beacuse that is a shorter flap off my viper so i would quit backing over it I could probably put the normal flap back on but to me it just looks kool!
Indy
Trucknut, first it will be hard for at least 600 miles, it will soften more and more each ride. Find some 8" stutters and BEAT it. It will get much better. I like the red wheels but the yellow springs I don't. I found a product at Lowes called Plati-Dip, in spray can form. It is a rubbery spray that worked great on my M10 springs. I can't tell, did you get the Ohlins? The only way to go.
trucknut
yes have the ohlins,I saw your post before about the paint for the spring and considered doing it but was also considering ohlins for the front to match they usally have yellow springs I think!
- 14K
