Rage or Renegade???
Quote frome Ski-Doo web site . Two injectors per cylinder ,inject fuel into
the transfer port . One small injector works alone at low RPM at higher RPM large injector also operates . Unquote . I think what you are see ing is a throttle body . It just regulates air flow amd operates the TP sensor .
It is not a caburator .
Guilty as charged.
mixing my dpm in there.
In any event a real high tech system that rivals 4 strokes for fuel economy. Almost perfect except for using oil.
I will see how the Vector chassis compares to the Rev chassis. I'm very impressed so far with the Yami 120 hp motor. This season should answer a lot of questions
