rx1 fern
i installed rail extensions on my 2004 rx1 short track. i went with the 144 tipped up rails and the hartman tunnel extension .my question is that the other day a buddy with a 2004 rx1 warrior was beside my sled and i was looking at his sled and his rear bracket is alot farther back.now that i went 144 ,should i relocate the rear bracket also.what will this do.will it lower the rear part of the suspension,as mine sits higher then his.will this help with more traction also.both sleds have the proaction on them.i know that if i move the rear bracket ,that the middle has to move also.thanks for any help.
rx1 fern
nobody knows or has done this before i guess.i will leave it as is then.was just wondering if it improved the ride a little.
05RXW
- Apr 22, 2011
- Caledonia, MI
- www.bigboytoydoc.com
hay where did you get your rail extensions? im looking to do mine an am trying to find the best place to get Good extensions.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
05RXW said:hay where did you get your rail extensions? im looking to do mine an am trying to find the best place to get Good extensions.
You could just move your skid back 4" and a killer attack angle. Get for on and off trail riding.
05RXW
- Apr 22, 2011
- Caledonia, MI
did you need new rear brackets or did you move those back too?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
05RXW said:did you need new rear brackets or did you move those back too?
If you are talking to me. Yes I moved the stock ones to. With over 3000 miles everthing is still working good. Here's the like to it.
rx1 fern
mine are track usa tipped up rails.ulmer racing sells them.i am thinking of relocating my rear suspesion from the 121 to the way the rx1 warriar suspension is .the brackets on the warriar are farther back.this should help since it is a 144 now.
redhead700
skid questions
the reason the rear brackets are farther back fern is to make up the difference from the longer rails of the warrior you wont be able to move the mounts back and be able to bolt the skid back it and also it will change all the geometry of your skid i ran my 121 with 144 extensions on my boosted rx1 this winter and really liked it the better way to go would be a warrior skid and shorter extensions or a different skid all together
rx1 fern
redhead700,why wont it work if all i am doing is moving it back and making new holes.i have warrior dop brackets used to install on my sled also.the 121 and 136 have the same skid besides the rails.
