rosco
I had one of the bolts that attaches the anti stab plastic caps to the fwd end of the suspension rail come loose. I removed the bolt and the cap to find an elongated bolt hole.
Has anyone had success repairing similar damage? I am thinking of haveing the hole welded and redrilling for the bolt. Then I will re install the plastic cap with some kind of an epoxy.
Any suggestions appreciated.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Silcone and rebolt it.
MT.man
Take the plastic cap off and JB weld the hole solid and drill it out . Easy and it has lasted longer than the stock set up did.
rosco
rail repair
I was wondering about jb weld. Are you saying that you did this with yours and it held up? If so I will probably do the same.
