Raising the front?
beeze455
Bowdoinham, ME
Website
www.gopherdesign.com
How high are others fronts from the lower bumper hole to the fround at rest? I have been messing with my suspension and I think i have gotten it up to around 10". My buddys M and my others buddys rmk sit much higher.
I have the skinz front end with evols.
Wjat is the secret to getting this front end to pop-up?
Beeze,
I have 13 1/8" from the center point of the lower bumper bolt to the ground sitting on a concrete floor.
Sled is a 09 XTX, 39"skinz front end, Timbersled rear skid, 60 psi in the front floats, 70 psi in the front skid shock,
limiter straps in the 2nd hole. (Sled is sitting on a 2" track and gripper skis if that makes a difference)
Mtnviper said:
Beeze,
Wow. Is this after you stand on it and jump up and down? Mine is at like 10"! I may be able to get it to 13 by lifting the front and hoping the shocks dont go down. I am going to check my shock pressures again. The must be messed up. Thanks!
beeze455 said:
Well it was the main chamber on my evols. I always checked it while riding or after. I lifted the bumper and found my floats wicked low.
Makes sense, as mentioned above you'll want to check the pressure with the shock fully extended.
BTW when I measured mine it was after I stepped off of the sled and allowed the suspension to rise back up and settle to its normal height.
I'm 14" to the C/L of the front lower a-arm and 12.75 to the lower bumper bolt. My evols are at 65psi main and zero in the other.
Nikolai, you're using the 16.5's? Did you try them last year too or is this new? Would like to do the same just to see if there is much difference with the Skinz front end....
OTM
My Skinz front end was built for 16.5" shocks. They moved the shock mounts on the production kits to run 17.5" shocks. It handles good with the shorter shocks.
according to fox you are supposed to do your air adjustments with the sled un-weighted / jacked up in air. hope this helps
