Just wondering where everybody is setting there min volt setting on there Apex? My Min volts are at 1.25 has anyone found that the RB3 responds better at a lower setting? Thanks
3 bar sensor on apex should be about 1.25 min and you can connect your computer and warm up sled and check voltage and adjust lower if needed for bigger injectors.
