herby
- Feb 3, 2009
nytro stage 2 mpi s/c, powderlites injectors (420 cc i think), 3 bar sensor. anyways i bought the rb3 from powderlites with program installed. sled hit rev limiter at about 8600 and ran like garbage, so phoned dave, he emailed me another map, jus took it for a rip and it seems to run a bit better, but still hits rev limiter at 8600. dave told me it was mike ???'s map for the same setup i have. anyone else having this trouble?? i ride mostly at about 6-7000 feet. any suggestions? thanks a bunch guys.
deepbreather
Check with Dave to make sure it has the correct 'project' in the box.
herby
- Feb 3, 2009
dave has sent me 3 programs, none of which were even close. i got one which had the rev limiter set correctly, however the sled was so rich it would hardly run. getting pretty frustrated with this rb3
deepbreather
Not talking about a 'program', ask him about an incorrect 'project' as a possibility.
T-Nytro
Also I see in another post you are having CODE 12 come up, crankshaft position sensor, this could be why you are having issues with the sensor or your rapidbike is the issue causing the crankshaft sensor code to come up.
herby
- Feb 3, 2009
guess i'll have to give dave another call, thanks guys
thamax
you need to put your sled in diag mode and check the codes before you blame the RB3 has the sled ever ran right or was this a problem that happened after the turbo install?
herby
- Feb 3, 2009
plugged my old programmer back in and sled fired up, so it was defianately the rb3. also tried to plug the rb3 into the laptop and it wont even read the rb3 anymore, so i'ts going back to dave for him to look at. sled worked fine last year, hasn't worked since the rb3 install this year. hopefully can get this thing figured out.
deepbreather
how you making out?
- 9K
