darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Darv - Unfortunately that RCA connnector part is rather pricey. It retails for over $80 and we sell them for $71.67 Here's the part number for it. Let me know if you need one. Thanks
TERMINAL COMP.
8HK-8254B-00-00
TERMINAL COMP.
8HK-8254B-00-00
darv
- Aug 9, 2005
- 08 Apex 40th LTX
thanks where on the parts is it also can i wire that in the system. the reason is I like to use ome parts all the time even if they cost a little more thanks
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
I believe I found it on the Electrical 2 section of the microfiche and if your going to install it on an 09 or older Apex you will need to custom wire it in as it there is not a connector on the harness to plug it in.
