Just wondering how often a person should be replacing rings in these engines. I have about 8100km on mine, its not using any amount of oil (maybe 200ml every 1000km, wich I change the oil at that point anyway). I did a compression test (dry) and got 190 across the board(yes, dead nuts even on my mac tools compression tester), but it seemed to be turning over quite slow(will try with freshly charged bat). Also have yet to do a leakdown or wet test. Plugs all look good, I am at 2400' above sea level, is there some sort of formula for elevation corection when doing compression testing? Should I quit worrying about these things untill I get another 8000km on it?
It starts great, even when at -20.
Just thought It would be good to have some insight from the more experienced here.
