Lonerider
- Feb 26, 2010
- south west mi
- 04 rx1, 05 Warrior 06 Attak-w/yamacharger, 07 Attak-Supercharged, 17 Sidewinder TD power trail
How do you get the rear axle nut off without braking it? It seems like I always end up braking the pin on the other side & it wrecks the threads. I am looking at the nut & it looks like it has a built in lock thread/washer, it seems to cut into the axle as I unbolt it. WORKS WELL!! , it is not a nylon?/lock nut.
chiefsledhead
Its just another regular lock nut. Should unscrew, just snug. Use a 17 mm one one side, a 19 mmm on the other and pull. If it doesn't come loose, then something is wrong, frozen or crossthreaded.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
chiefsledhead said:Its just another regular lock nut. Should unscrew, just snug. Use a 17 mm one one side, a 19 mmm on the other and pull. If it doesn't come loose, then something is wrong, frozen or crossthreaded.
X2 just a normal yamaha selflock nut. Can u post a pic.
Lonerider
- Feb 26, 2010
- south west mi
Got it off, pb blaster, & heat
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I had the same problem with that style lock nut. I had to get a new axle after all the threads got damaged and I could tighten the axle up. Stupid design if you ask me.
