apex55
I had recently discovered I was missing a tension nut on one side and have ridden like this without kowing for some time. Today as I fixed this I noticed my outside wheels were wobbling. Fearing bushings I pulled them out and checked the bearings, they were fine.
Here is my axle question.
When tightening the axle the hex nut is butting up against the axle itself. I have torqued it but after I can spin the axle with a wrench so it appears it is not tighting on the rails. Is this correct. Also the wobble in the bushings seems to be an incorrect spacing with the spacer not hitting the bearing. Any insight would be appreciated.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Do you have all the washers.
granto211
thats what the point of the axel spacers and washers are for so u can tightn without affecting spin of wheels. the more you tighten though the harder it is to adjust track tightness. put som blue lock tight on it and snug it up
apex55
From looking at the fiche I say yes. I am suprised it didn't tighten securley on the rails. I haven't take the whole assemly out yet, but plan to do so in the spring as I am going to send the mono shock to half baked for their rebuild. Just wasn't sure if this is how it is supposed to be.APEX 06 said:Do you have all the washers.
apex55
It' is tight but still have a slight wobble in the wheels. Just seems weird to me, but then again I am just getting into my own servicing and am learning as I go.granto211 said:thats what the point of the axel spacers and washers are for so u can tightn without affecting spin of wheels. the more you tighten though the harder it is to adjust track tightness. put som blue lock tight on it and snug it up
granto211
im no pro but u may need wheel replacement as what i had to do last week. we all learn as we o
its a hobby and i love it thanks to people on here who help u out as we get stuck. if u pull out the whole rear axel which isnt to bad be carfull to remember the order in which the spacer and washers go.
granto211
as we speak i got the laptop in the garage changing my gears and track for the first time.
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
granto211 said:as we speak i got the laptop in the garage changing my gears and track for the first time.
I kinda wondering how is the process of taking the chaincase apart? Just picked up a 2006 attack that will be apart this summer.
granto211
if theres a will theres a way
http://www.totallyamaha.com/snowmobiles ... 20prt1.htm
just gettn into it ill know more in an hour
quebec#1
Just changed my outside rear wheels for the 2010's. no more wobble.
