Rear guild idler wheels?
Kyle Johnson
Interlochen, MI
2005 rs rage
I've got an 05 rs vector that lost a rear axle guild wheel. Nut side on rear axle.
I picked up a slightly older? rear wheel(R0178e/b10), and it has replaceable bearing(6004)
So, can I use this one to get me by, is it also the 178mm size(looks the same diameter.
I plan on going through all the idlers on the 05 vector and the 05 rage in the spring. I would like to use the ones with the replaceable bearings if possible, but having trouble finding them, or the "correct" rear axle wheels for sale.
Any links or part numbers would be appreciated.
i bought a pair of those to put on my brothers sled when i stripped off the aftermarket performance wheels. from what i remember they did have a snap ring so the bearings could be changed. sled is under 3' of snow atm though.
