Rear Idler Wheels
yamaslob
Saranac Lake, NY
Maybe some one can clear this up for me. Last week I blew out the bearing in my center rear wheel on my 06 Apex RTX, no big problem replaced the wheel a simple 20$ wheel, then this saturday I blew out one of my outer wheel same thing blew out the bearing. I go to look onlike there 40 something dollars a wheel, via port-yamaha. Why so expensive, could I simply replace both of my outer wheels with the inner black wheel?
Number 35 is what i need on the online finch could i simply replace all of them with the number 34 wheel?
http://www.portyamaha.com/fiche_section ... &fveh=5310
thank you
-James
I'm sure it will work. They both share the same bearings, plus I believe the bearing is replaceable on the center wheel, no?
Where did you get a Yammy wheel for $20?
It was 25$ in change, excuseeee I called the dealer and he said they have a couple Kimpex wheels in stock, same as the stock yamaha wheels, hope these do the trick.
-James
The Kimpex wheels may have a 6204 bearing, which will fit on the axle, however modding the spacer is necessary to make the bearing fit as it is 3mm wider than the stock 6004 bearing. Check with the Dealer to be sure.
I just ordered a set of rear wheels for my Nytro. They are supposed to fit certain Arctic Cat sleds and are actually 1/8" larger in diameter. My hope is that it will help reduce my horrible slider wear.
