walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
alright guys, I may not be 100% what the part is called but its the black bar that runs on each side of my rear shock. I took the sled for a ride today and I heard like a metal rattle in the skid. did some digging and figured out that this rear linkage, or what I believe to be the linkage has some slop play in it. Like I said it runs on both sides of most rear shock, bout 15 in or so by 2 in roughly. Anyways is this supposed to be loose and have play? haven't tried to tighten yet only because I cant find any info on this topic. Help me out boyz! oh and its a 15 viper ltx
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
oh and I also tightened my limiter straps prior to the season. not sure if that may of had an effect?
Studroes144
- Oct 30, 2013
I know what you mean, mine actually seemed to have some play right out of the crate, they were chucking on the shaft but had and still have some side to side play which I can hear on occasion.
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
did you try to tighten at all? anything you have done that has made it better?
Studroes144
- Oct 30, 2013
Don't believe there's any tightening to it since it's on a shaft and can't get the bolt any tighter than what it is.
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
so its just one of them things then we just have to put up with?
Yes. Everything on that skid is loose to avoid sticktion. Works well. No worries.
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
thanks a lot guys! I think the only reason I heard it was because I wasn't wearing a helmet and never noticed in the past!
