Rear shock adjustment on a 07 RTX
Terminator
Atkinson, NH
As most of you probably know, unlike my 06 Attak, my 07 RTX does not have the dial for shock adjustment on the side of the tunnel. The RTX does have a set screw near the shock resevoir for this. I'm assuming that turning it in (clockwise) will increase stiffness. I just had my rear shocks revalved and they are really stiff and I can't feel the difference when I play with it.
Does anyone have first hand knowledge on this?
Thanks.
Thanks.
To answer your question, yes, turning it in will make it stiffer.
Beyond that, I would suggest you talk with the guy that did your valving. If he put a multi stage kit in there, turning the compression damping up COULD disable that - efectively bypassing the work you just paid for.
Thanks Ahicks, I'll give Bruce @ Pioneer Performance a call to make sure I don't waste all that money I spent on 2 revalved shocks and Bigboy spring.
