kered
- Mar 22, 2014
- Newmarket, Ontario
- 09 Apex GT
Can anybody help with removal of rear shock Apex gt Ohlins without removing the whole skid?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Lift the rear, remove 1 bolt from transfer rod, remove bolts from shock and unplug wire, remove shock from skid.
kered
- Mar 22, 2014
- 09 Apex GT
Which bolt do I remove from the transfer rod?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I take out the front one.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
back off the spring right off. remove 2 bolts for shock and undo electronic wire. Dont have to touch transfer rod.
kered
- Mar 22, 2014
- 09 Apex GT
Any help with re-installing the rear shock? I took out the front bolt of the transfer rod and as the sled was sitting on the ground the rear arm has gotten wedged between the rails and I cant get the bolt hole to line up for the transfer rod.
