NS FX NYTRO
Quick question, 2008 standard fx nytro, my rear skid shock (one with no spring) is the nut and centre flat head screw on the piggy back resi for hi and low speed compression dampening? My mxz 440x looked similar, but not sure if it's the same on my nytro rear shock.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
Yes. It's compression dampening. It's 12 position adjustable from turned all the way clockwise being the stiffest setting
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Yes, it's the brass coloured, small, slotted screw head. There are 12 clicks. They are very slight, not as easy to feel as the front clickers on the gytr's. Don't think about turning the big hex head it sits in or you will Crack an o ring seal and oil will leak out.
Ms
Ms
NS FX NYTRO
Perfect, thanks guys. I know on my mxz 440x the centre screw had less noticeable clicks when turning. I'll check out where its set at in the morning before I hit the trails. Season is still going strong here in the north east of canada.
