bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
Polaris profile rails are on the M-20. You can make the Yamaha profile fit (and then be able to run Duponts) by shimming the bottom of the rail with a long thin piece is aluminum strap. The Polaris and Yamaha profiles really only differ by the height of the "hooks" that hold on to the top of the rail (Yamaha profile is slightly taller).
00-NUKE
Is the M-20 hard on slides to where I should look at using the dupont slides? Or does it do pretty good with stock slides?
00-NUKE
Thanks for all of the info guys!
bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
1000 miles is about the max I have ever gotten... can be a lot less obviously if snow conditions are not good. I haven't ran the Duponts yet, but I will be trying them as soon as I need to replace my current hyfax.
00-NUKE
I run the Duponts on my nytro XTX. They work awesome!
try using some scratchers on low and frozen snow conditions. I am on my second season and they still look mint! I also added the mid wheel to reduce wear in the middle of the rails. I also have the 136"
SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
My m20 burns up the slides right behind the first wheel. I just tighten up.my limiter strap think that might help as the skid sits flatter
guys, according to my dealer, Yamaha is going to be making duponts for all brands.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
This is true, Polaris and BRP profiles are available
