Ohiokm
- Nov 24, 2020
- Ohio
- Yamaha Nytro RTX
Hi there, I have a tech question. Will a 2011 Apex 128" full rear skid work and mount in a 2011 Nytro RTX 121"???? Thinking about a full rear skid/ track swap out to a longer skid/track.
Thanks in advance
Thanks in advance
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
You can just relocate your skid. https://www.starsuspensions.com/
- Jun 28, 2004
- Clinton, Wi.
You'll need the donor sled tunnel mounting dimensions plus any brackets. Once you layout the mounting hole positions, dry fit the brackets to clear out any interference. I've swapped multiple suspensions into trailing arm sleds and Apex chassis. I currently own a Nytro with an Arctic Cat 141 skid in it. It was installed by the previous owner and works very well.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Check out the BOP website or shoot Travis a message. He’s got an easy peasy install kit to locate a Mono skid into the FX chassis. I used one last fall to mount a 136” Mono II skid into my project Nytro with one of his progressive rate springs and it works fantastic!
Ohiokm
- Nov 24, 2020
- Ohio
- Yamaha Nytro RTX
BOP website?
Travis?
Anymore info?
Thank U
Kirk
bop= barn of parts. site sponsor and the owner's name is travis.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Thanks Maim, I was a little short on info there.
