raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
Tryin to take some ski pressure off my attak, i was gonna lengthen the front limiter strap. Any other thoughts??
quebec#1
Also play with your front springs.
Check out the FAQ's and darting stickies at the top of this forum
410shooter
Ski pressure
I just went from a Apex ER 121 inch track to Apex LTX GT 136 inch, I want more ski pressure. Shorten the limiter strap or can I do anything with shocks up front???
darv
- Aug 9, 2005
- 08 Apex 40th LTX
make shure you adjust your sag it is very important and shim your skis it works great i have apex ltx gt i put C&A Pro razor on shimed them 3/16 think shim, 13mm sway bar , transfer rod
1/4" from max and one turn off my front springs works great i have bad shoulders and this sled is the best Yamaha i had every owned thanks BOUNTY HUNTER for all the help
