? Regarding a 1.5" Track
Boston RX1
Laconia, NH
Will a 1.5" track fit in an 03 RX1? I would like to do some cross country riding and would like better traction/floatation. If so, will this make a difference and what track would you recommend? I do 90% groomed trails and I do not want to loose any performance on trail. I think a different track would be cheaper than another special purpose sled. Any ideas?
If your mostly trail riding, do not go to 1 1/2". This will increase vibration and increase the distance between a well groomed trail's loose snow and your hyfax. 1 1/4" is plenty.
I assume you are not looking at studding? Trying to get stud to hold in a 1 1/2 " track is very unlikely. Or, ... try a 1 1/4" Ice Ripper with the studs built in. While it is not as agressive as picks, it is much saffer than w/o studs.
Besides, these tall tracks tear the heck out of the trails. However,, ... If you are going to go a lot more off the trail, then you may want to consider going taller than 1 1/4". But, then match that new track up with some skis that will float a bit better.
