Paraclete
I was hoping someone could tell how to remove the seat off my 07 attak so I don't waste time on stuff that doesn't need to come off.
- Jun 28, 2004
- Clinton, Wi.
Exhaust caps, rear plastic including taillight. Then you'll see 2 j-hooks that hook to brackets on the muffler heat shield. Loosen those nuts all the way off . Lift the rear of the seat up and then pull towards the back of the sled. On my 06Attak, only2 of the exhaust cap bolts actually attach the caps. Don't ask me which 2 though, because I don't remember Lol,,
Paraclete
I took the j bolts off now I guess just pull back and up?
There are no bolts to remove on the front?
MT.man
No the seat has a tab the slide under the tank. but dont forget to unplug the taillight , right hand by the lower plastic cover
Paraclete
That connector is real biatch what the hell
I Push the little tab and still can't get it a part
UUURRRGGHHH
UUURRRGGHHH
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Sometimes connectors need to be pressed tighter together in order to fully release the retaining clip. Also you can try using a small screw driver or a pic to push the release clip farther than you are able to with a finger,
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Soldier'spapa said:Sometimes connectors need to be pressed tighter together in order to fully release the retaining clip. Also you can try using a small screw driver or a pic to push the release clip farther than you are able to with a finger,
And use dielectric grease when putting them back together, after you have cleaned them if they are corroded.
