If you add the block off plate, you can leave the protectors on. I had no ice build up once I riveted the plate in place. Then I went to a rear mount Turbo, had to remove the plate, then had ice build up again! I bought a thin rectangle piece of steel from Ace Hardware and perfectly shaped it with a tin-snip and riveted in place. Worked flawlessly.....
