munskindaddy
Was wondering if anyone ever replaced the rubber boots in front end that tie rod slides thru. How did you get to the rivets on the inside? The left one looks possible, but the right side looks like a real bear to get at. Any procedures would be appreciated.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
die grinder to grind off the heads of the rivets then punch them out.
munskindaddy
So I grind from the inside? Then how do I get a rivet gun in there to put the new ones in?die grinder to grind off the heads of the rivets then punch them out.
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Put them in from the outside.
