RobWal
- Jan 13, 2009
Hello Everybody, I currenty have a 04 RX Warrior and the handle bars are way to low. I would like to raise them about 6 inches, but I will need longer throttle cable, brakes lines, choke cable, and possibly longer wires for electrical. I have found sites that have the throttle cables, brake lines, and the riser. But would a whole setup from a newer yamaha mountain sled work?? Or just any advise on how I can get what I want would be awesome.
Plus as you all know, the skiis on these sleds are way to narrow. They just sink and dont float at all. Has anybody switched to a WIDER ski that helps? I hear simmins makes a wider ski but the dimensions seem to be pretty close to what I have. Any thoughts??
Thanks, Rob
Thanks, Rob
adrenaline junkey
I cant really hep you on the bar questions but simmons does make a generation 2 ski 10 inches wide and floats like a duck in water
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
Heres some info on skis.I can also set you up with risers,cables.Any questions let me know.thanks
http://www.richmotorsports.com/store/vi ... IMVYLU7166
RobWal
- Jan 13, 2009
Those Skis will be perfect!!
And yes richierrich, Please set me up or in the direction for the riser etc. I need everything to put them up to 6 inches+.
Thanks very much guys!!
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
hi
heres some prices.i have several options for risers.heres a link.any questions let me know.thanks
http://www.richmotorsports.com/store/in ... Bar+Risers
long throttle=$30
long brake=$50
long throttle=$30
long brake=$50
