stephenpen
I'm looking for a Riser but I'm not sure how big to go.
I have apex bars without the big bend. My hand gaurds hit the plastics over the tank when I turn sharp.
Do I remove the stock riser or do I get a block to add to the stock riser.
When I stand up I have to hunch over a bit. I'd like to stand up staight.
shadow44
Powermadd makes a Nytro specific 4" riser...your stocker is 2.5"....Check out some of the site sponsers on here if you want some really trick stuff, Lake Effect Snow or NCI have the nicest stuff I've seen.
stephenpen
Do you think the 4 inch will do. My bars sit alot lower then stock nytro bars.
shadow44
Do you have an RTX or Std version? How tall are ya? I'm 6' , my sled has an OFT relocator and a stock RTX riser (however it's mounted on an XTX post as my RTX post got bent last season so no more pivot ) standing or seated is perfect for me.....it's a tic better than last season which had my riser sitting straight up
shadow44
I saw pics of your sled on HCS....put your riser straight up instead of angled back to you...it may help.
stephenpen
I'm going to do that for now. I was looking at the Apex bars VS the Nytro bars and there is not much difference in high. The first nytro bars I compared my apex bars to must not have been stock. They had a huge bend rising the bars up maybe 4+ inches.
tankeryanker
I'm running a 5.5" rox riser and the apex bars on my 2010 xtx with no problems at all. Was worried about the throttle cable and brake lines being to short but it worked out perfectly
Muffin
- Oct 5, 2006
- Marathon, WI
- 2014 SR Viper RTX SE
Please check out our new design risers. We have them in 3 different sizes. All are highly plolished and come with all the stainless steel hardware. They are very easy to install. Our risers can pivot to customize your riding postion and once locked down they will not move thanks to our new pin and socket setup. If you have any questions let us know.
Do some searches on our stuff and I think you will be pleased by the feedback.
www.muffinworksltd.com
sales@muffinworksltd.com
