riser?
drunkenrich
Thomaston, CT
what is the highest I can rise the bars on an 09 XTX without buying throttle and brake line extension?
We put a 3.5" Rox on my buddy's XTX.
On the Mag side of the sled there is a cut in the Rad shroud where the brake line runs up. You can free up a lot of length if you just make that cut bigger. I did that on my sled as well.
can you take a picture of this for me?
Both Lake Effect (Superman here on TY) and NCI (Arteeex) are site supporters and make great risers. Both add bling to your sled, are durable and are affordable.
Sorry I don't have a picture of it after it was cut. But as you can see from this picture there is a cut out of the bottom of the plastic rad shroud and the brake line runs up thru it. If you make the cut out larger (so it goes higher) it will free up more slack in the brake line.
