Roll Over Valve Help
HUNT 24/7
N.B
Canada
Nytro
Bought a used roll over valve but it doesn’t look the same as the 4stroke Solutions setup.
This one has a brown ring connector wire coming from the small red light & also 2 black wires into 1 ring connector, I think the double black is the ground but not sure what the brown wire is, can’t find it in any pics online. I know what everything else is & yes, I do have the roll over valve, it's just not in the pic.
Any help would be greatly appreciated!
[/IMG][/IMG]
Does one of those O connectors go to ur starter selenoid?
I don't think so, but Im not sure what it is at all really. Lol
Was hoping someone here might know.
Hunt 24/7
I replied to your email as well. The ROV pictured is an older Yamaha unit that was made by MPI. The LED is something that a previous owner added as those units were not originally equipped with one.
The double wire eye is ground and attached to chassis ground. The Brown wire with the eye that is routed to the LED, I assume is a ground wire for the LED light itself and would also be connected to chassis ground.
Since it sounds like you didn't receive any instructions with the ROV when you bought it, the valve is directional. So it is extremely important to plumb the valve in correctly (not backwards) for proper breather air flow to occur.
Bill
