hypertxer
i just bought a roller secondary of mountain performance and i got a 44-36 helix is that the right one. my mods are ulmer stage 3 clutching with top gear, hauck exhaust, cr10ek plugs, hauck fuel accelerator, airbox mod, 144 studs what would be the best setup
Rash
Sounds all good to me...
nice start, but i can't tell you from memory what i had in mine, sounded a little like that...
hypertxer
i have a supreme tool roller on my 06 i have my sled set up for drag raceing 660ft i have a yellow cat spring with a 54/38 cut helix. spring set in middle hole. im not to up on the mountain secondary but my sled rips with this combo in it i also run supreme tool weights in the primary with a 23t gear. supreme tool weights are very close to ulmers. hope this helps .
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
everybody's helix/roller units act differently...you're going to have to just run it..but Id say its about the closest you can get WITH THAT ROLLER UNIT...you will have to tweak your weight setup though..
